1989 Chevy Suburban Tailgate Window operation with key from
61,430 MILES • V8 • 2WD • AUTOMATIC
SGTNITRO
My rear power tailgate window was smashed and then replaced. When I got the truck back, the tailgate power window would not open or close with the key from outside the truck. The window works fine from the toggle switch inside the truck., just not with door key. BTW: the key does turnn full left and full right while in the tailgate window acutator, but nothing happens to the window. Any suggestions?
Oct 2, 2009 at 12:46 AM
IMPALASS
  • 3,112 POSTS
Hello –
To better assist you please tell me if your model is the R1500, R2500, V1500 or V2500, your engine size in liter and the 5th and 8th digit of your VIN.
Oct 3, 2009 at 7:03 PM
SGTNITRO
I'm not sure if it is a R1500 or a V1500.
The motor is a 5.7 liter, 350 ci
the fifth digit on my vin is: R
the eight digit on my vin is: K
Hope this helps!
Oct 4, 2009 at 3:50 PM
IMPALASS
  • 3,112 POSTS
Hello –
Thanks for the info……..lets go with R1500
Please check fuse 13 with an ohm meter to make sure it is good.
You will need to remove the rear panel and check to see if any rod or plug is disconnected. I am sorry as there doesn’t seem to be any diagram for this in the manual.
Oct 5, 2009 at 12:36 PM
IMPALASS
  • 3,112 POSTS
Hello - Also, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_1500_Recall_1.jpg
Oct 5, 2009 at 12:39 PM
