1989 Chevy Suburban idle
JUSTALEX13
Engine Performance problem
1989 Chevy Suburban V8 Two Wheel Drive Automatic
it has a high idle. i replaced the IAC valve with no improvement.
Jan 18, 2009 at 10:18 AM
  • 75,988 POSTS
Did you clean out the idle air control valve passages thoroughly and test the throttle position sensor-
Jan 18, 2009 at 10:23 AM
JUSTALEX13
Thank you I will try that.
Jan 19, 2009 at 11:02 AM
