1989 Chevy Suburban brake
165,000 MILES • V8 • 2WD • AUTOMATIC
HELL RAZOR
i have a 89 suburban and i had my brake ligth on for almost a year i got it from a friend i cant find anything that would make the ligth stay on i replaced the brake ligth swigth and also all the bulb and my brakes work good
Sep 20, 2009 at 6:52 PM
HMAC300
  • 48,601 POSTS
pull up on the parking brake pedal and see if the light goes out. If not then there may be a master cylinder or ABS problem if you have ABS. If it's got ABS it can be a bad sensor, wire, or anything similar...
Oct 6, 2009 at 11:13 AM
