I am trying to get it smoged, but the light won't come on. service engine soon light
Oct 7, 2010 at 7:06 AM
JDL
✓Experienced Mechanic
Maybe the bulb is just burned out? I worked on an 89 sub one time, the mil wouldn't work on that one either. I used a scanner that shows live engine data at the datalink connector, worked just fine. I'm not sure how hard it is to get at the bulb, usually working on dashes, I always break something.
Oct 7, 2010 at 7:31 AM
COWBOY 63
MEMBER
I believe they put that bulb in and then built a car around it. It is a lot of work to get to the bulb. It wasn't even burnt out. I just pushed on it and it came on. Even better I started the car and it went off. Thanks guys, you gave me the confidence to even try. Cowboy 63
Oct 8, 2010 at 4:02 AM
JDL
Yeah, I've seen the same thing. 80 model camaro, no excite voltage to alternator, the charge lite didn't work. I didn't want to get into the dash, but I did. Turned out the charge lite bulb had just vibrated loose over the years, I just pushed it back in. Everything worked ok, charging again.
