1988 Chevy Suburban can you help me ???
70,277 MILES • V8 • 4WD • AUTOMATIC
RKMAYHUGH
High Oil Pressure i put in same type oil it ask 10w - 40 and it also burn oil so what going on
Sep 26, 2009 at 4:54 PM
HMAC300
  • 48,601 POSTS
If the oil pressure is around 50# it's nothing to worry about. The oil burning is probably due to being old and the seals being worn out on the valves. As long as you are not using more than a quart of oil every 500 miles it is considered normal consumption. But if you got new valve seasl it wouldmore than likely cut down on consumption.
Oct 6, 2009 at 11:08 AM
