1987 Chevy Suburban Idling Issue
PASCUA
Engine Performance problem
1987 Chevy Suburban V8 Four Wheel Drive Automatic 150k miles
My 1987 Suburban will not maintain a steady idle and a miss at idle. it idles up and down, but when driving it runs great. I suspected a vacuum leak, checked and no leak found, replaced air intake valve, map sensor, spark plugs and wires,egr valve, changed throttle body and gasket.
Any help would be greatly apperciated.
Sep 29, 2010 at 12:13 AM
WRENCHTECH
  • 20,760 POSTS
They had a lot of problems with the throttle bodies on those with leakage in the base, sometimes from the EGR and sometimes vacuum.
Sep 29, 2010 at 12:16 AM
REDWHITE
same problems with mine. no vacuum leaks, acts as if it would flood itself out. I also change the map sensor with no change need help
Oct 16, 2010 at 3:25 AM
WRENCHTECH
  • 20,760 POSTS
[quote:344f632396="redwhite"]same problems with mine. no vacuum leaks, acts as if it would flood itself out. I also change the map sensor with no change need help[/quote:344f632396]
Please start a new question of your own. We can't follow 2 vehicles in the same thread.
Oct 16, 2010 at 3:38 AM
