1987 Chevy Suburban Idling Issue
PASCUA
  • 1987 CHEVROLET SUBURBAN
Engine Performance problem
1987 Chevy Suburban V8 Four Wheel Drive Automatic 150k miles
My 1987 Suburban will not maintain a steady idle and a miss at idle. It idles up and down, but when driving it runs great. I suspected a vacuum leak, checked and no leak found, replaced air intake valve, map sensor, spark plugs and wires, egr valve, changed throttle body and gasket.
Any help would be greatly apperciated.
Wednesday, September 29th, 2010 AT 7:13 AM
WRENCHTECH
  • 20,761 POSTS
They had a lot of problems with the throttle bodies on those with leakage in the base, sometimes from the EGR and sometimes vacuum.
Wednesday, September 29th, 2010 AT 7:16 AM
REDWHITE
Same problems with mine. No vacuum leaks, acts as if it would flood itself out. I also change the map sensor with no change need help
Saturday, October 16th, 2010 AT 10:25 AM
WRENCHTECH
  • 20,761 POSTS
Please start a new question of your own. We can't follow 2 vehicles in the same thread.
Saturday, October 16th, 2010 AT 10:38 AM
