noticed driving home from work, started to run rough no power. next morning tried to test for problems. idles up and down. put in gear and tires to die then idles fast enough to move the truck then back down again. pulled the vacuum hose from the MAP sensor and it idled much better. Bought a new MAP sensor and didn't help. pulled the vacuum hose from the EGR sensor and no change. no codes on system need help. I did pull the vacuum hose from the air sensor and plugged into the egr valve and ran much better. This morning about 40 degrees outside rough idle, but engine had better response on acceleration. afraid to take out on road.
Oct 16, 2010 at 3:19 AM
