1986 Chevy Suburban sloppy tilt steering wheel
194,489 MILES • V8 • 2WD • AUTOMATIC
LANDCRUISER1
I have the steering wheel off and the signal switch removed. How do I tighten the tilt column?
Feb 9, 2008 at 9:39 AM
MASTERTECHTIM
  • 4,750 POSTS
there are 4 inverted torx head screws that have to be tightened deep inside column. you will probably only be able to get to 3 of them without totally disassembling the column. tighten 3 of them and the play will be gone.
Feb 9, 2008 at 9:43 AM
LANDCRUISER1
[quote:05d447fcd8="mastertechtim"]there are 4 inverted torx head screws that have to be tightened deep inside column. you will probably only be able to get to 3 of them without totally disassembling the column. tighten 3 of them and the play will be gone.[/quote:05d447fcd8]
How do I get to the 4 torx screws? I have removed everything up to and including the signal switch.
Feb 10, 2008 at 4:31 AM
MASTERTECHTIM
  • 4,750 POSTS
you have to go a little deeper. you need to depress the lock plate and remove the c clip to remove it. then you can access the inverted torx screws. you might be able to rent or get on loan from your auto parts store, its called a lock plate depresser, it makes getting the c clip out a lot easier.
Feb 10, 2008 at 9:42 AM
LANDCRUISER1
I have done that. I am past removing the lock ring and the signal switch, how do I get to the 4 screws?
Feb 10, 2008 at 1:22 PM
MASTERTECHTIM
  • 4,750 POSTS
i use long extension with the inverted torx bit and snake it right through, you can only get to 3 of them. if your bit is too wide try taking it to the grinder to make it thinner.
Feb 11, 2008 at 8:34 AM
