1986 Chevy Suburban it wont fire, no spark to plugs
TODDWOOD
Engine Mechanical problem
1986 Chevy Suburban V8 Four Wheel Drive Automatic lots miles
it turns over but wont fire
May 18, 2010 at 5:48 PM
INTERNETMECHANIC
  • 700 POSTS
How long since a tune-up? Is coil in the cap? If so, use a testlite at the cap tach terminal. Engine cranking the lite should pulse. Also check primary voltage to cap, pink wire, goes hot when you turn on the key. There are other possibilities, but, that will get you started.
May 19, 2010 at 7:12 AM
