On V8 engines remove the upper bolt from the right front engine mounting boss and insert a long bolt 3/8-16X2in to hold the fuel pump pushrod.
Remove the 2 pump mounting blots and lockwashers, remove the pump and the gasket
If the rocker arm pushrod is to be remove from the engine the 2 adapter bolts and lockwashers and remove the adapter/gasket.
Instal fuel pump in reverse manner put heavy grease on the pushrod to hold the rod while installing the pump.
Good Luck
SPONSORED LINKS
Sunday, September 21st, 2008 AT 8:43 PM
