1983 Chevy Suburban Alternator/charging system
1983 CHEVROLET SUBURBAN
140,000 MILES • V8 • 4WD • AUTOMATIC
EFBEZZINA
I replaced my alternator needlessly cause the new one is doing the same as old one. I'm not getting voltage out of the back of the alternator post and after jumping the voltage continually drops. Does this sound like a bad ground? or could it have something to do with the ignition switch. help!
stuck in Vegas
Dec 23, 2007 at 9:15 PM
SERVICE WRITER
  • CAR REPAIR CONTRIBUTOR
  • 9,123 POSTS
I would be VERY suspicious that you may have gotten a defective alternater right off the shelf.
In some instaces, rare, (but it happens) we have had 3 bad ones right on the shelf on some applications.
Test the alternater.
Dec 23, 2007 at 9:23 PM
EFBEZZINA
[quote:a3ac34f97b="Service Writer"]I would be VERY suspicious that you may have gotten a defective alternater right off the shelf.
Test the alternater.[/quote:a3ac34f97b]
Dec 24, 2007 at 8:30 AM
SERVICE WRITER
  • 9,123 POSTS
Was that an echo I heard?
Dec 24, 2007 at 11:46 AM
EFBEZZINA
Thats not an echo that was me trying to figure out how to reply, I'm new to this. Anyway I did have both alternators tested and they were both good. I then replaced the battery and the ground cable from alternator to battery and cleaned up some connections. So far so good. I'm just confused cause I even if the battery was bad, shouldn't the alternator still be putting out 12volts off the back post. thank you for the reply and I did donate.
Dec 24, 2007 at 4:22 PM
