how to adjust back doors
Nov 24, 2006 at 1:56 AM
Check for worn rear-door hinges. Where possible, loosen the hinge bolts to see if the doors can be adjusted, and inspect the catch to see if it is adjustable.
The owner of a 1978 Chevrolet Suburban with over 100,000 miles asked how to adjust the rear doors. The expert said the hinges may be worn and suggested loosening the hinge bolts to check for adjustment, and also checking whether the door catch is adjustable.
