1978 Chevy Suburban Cruise control
140,000 MILES • V8 • 2WD • AUTOMATIC
SUNGLASSES1991
A couple of monthes ago I was on the freeway and I turned on the cruise control. When it came time to get off, I hit the brakes to disengage the cruise, which it did, but when I took my foot off the brake pedal the truck accelarated back to 60 miles an hour. The only way to shut it off was to hold the brake and shut the engine off. I then disconnected the three vacuum hoses on the cruise under the hood on the left fender. Is this fixable? If not what do I have to replace. My Speedometer and everything else works normal.
Thanks in advance.[img:f222533f56]http://www.2carpros.com/forum/automotive_pictures/158632_IMG_0436_1.jpg[/img:f222533f56]
Feb 15, 2008 at 6:08 AM
THIS IS MIKE
  • 686 POSTS
Wow, that must have been scary. You will need to replace the entire cruise control. The actuator that controls the speed is malfunctioning and needs to be replaced. Avoid using the cruise control until you get it repaired.
Feb 21, 2008 at 2:35 AM
