03 Suburban Z71 vortec fuel pump
KD202
  • 5 POSTS
Fuel pump went out, replaced it yesterday, but it's idling low and acting as if wanting to stall... Replaced with OEM AC Delco for flexfuel... any suggestions? :roll:
Jul 29, 2007 at 7:11 AM
2CARPRO JACK
  • 11,533 POSTS
Did you do the filter at the same time? Is your truck a flex fuel vehicle? Check the fuel pressure regulator on the side of the fuel rail.Remove the vacuum line and see if there is raw fuel in it, if so replace regulator
Aug 10, 2007 at 10:59 AM
KD202
  • 5 POSTS
[quote:ad57d09e1b="2CarPro Jack"]Did you do the filter at the same time? Is your truck a flex fuel vehicle? Check the fuel pressure regulator on the side of the fuel rail.Remove the vacuum line and see if there is raw fuel in it, if so replace regulator[/quote:ad57d09e1b]
Yes we did replace the fuel filter
Will check fuel pressure and vacuum line thanks :)
Aug 11, 2007 at 4:29 AM
