Chevrolet Spark
46,000 MILES • 1.0L • 4 CYL • 2WD • MANUAL
MICHELLE BOYD
When I'm sitting idle at a red light the car it like kicks I call it a heartbeat but it is getting worse have had it plugged into a computer and nothing is showing up there's no lights on either . Have put a catalalage converter cleaner through it and made no difference no one has any idea what it could be. I can feel it under my seat when it happens when driving it's fine it's only when I'm sitting idle.
Apr 4, 2017 at 11:51 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate o both sides and iac hole with choke cleaner they get gummy and do all sort of screwy things normally at idle. then check for a vacuum leak or air leak like duct work leading to engine and grommets cracked or broken on engine.
Apr 5, 2017 at 12:00 AM
MICHELLE BOYD
Thank you very much I will try these and see fingers crossed.
Apr 5, 2017 at 12:03 AM
  • 55,711 POSTS
Best, Ken
Apr 7, 2017 at 4:48 AM
