Check for power to the pump on the right tank, if there is power there, it's probably the pump or the connector. In which case I would check fuel pressure and volume if necessary from that right tank. If there isn't power to the pump may be at the switch. Not sure if there is a separation of fuses or relays between the pumps, you'll need to check that on the fuse. Realy box (es).
SPONSORED LINKS
Wednesday, October 10th, 2007 AT 7:35 AM
