turn signal problem
SNOWBALLPETE
2003 silverado
when using the right turn signal, both signals flash(as if the flashers are on)
left turn signal works fine
Mar 8, 2007 at 5:11 PM
MIKE H R
  • 3,094 POSTS
check the connections on the right signal light at the bulbs. if corroded clean them and reinstall the bulbs. whenyou use the right signal light does it look like the signal light on the left is flashing or is it look like the tail lights are flashing?
Mar 9, 2007 at 12:35 AM
