When you say jump, what exactly do you mean?
Does it lurch forward like you revved the motor and dropped it into gear?
Or it's shifting very hard from 1st to 2nd?
If it's the latter, your transmission is starting to have valve body problems. Remove the battery (disconnect it) for about a half an hour and this will reset the computer. It should shift normally after this.
If this doesn't work, I'm afraid you might be looking at a tranny overhaul.
Good Luck
SPONSORED LINKS
Wednesday, August 8th, 2007 AT 2:57 PM
