2000 Chevrolet Silverado Tow Mode Fix
TED POSSNETT
2000 Chev Silverado 2 wheel drive 2500 3/4 ton this vehicle is equipped with towing package. Tow mode is not working and repair shop cannot find problem. Could the engine/transmission be damaged if I haul 4500 lb trailer for 500 miles with tow mode not operating?
May 30, 2006 at 10:29 AM
LOSONE
  • 1,616 POSTS
All the tow mode does is lock the transmission overdrive out. Try and put it in the next lower gear with the gear lever and see if that feels like you are in the tow mode.
I do think you have an electrical problem with the tranny. Do you have a check engine light on??
Let me know
May 30, 2006 at 10:59 AM
Suggested Repair
Select the next lower gear manually, since tow mode only locks out overdrive. Suspect a transmission electrical fault and check whether the check engine light is on.
Conversation Summary
The owner of a 2000 Chevrolet Silverado 2500 with a towing package says tow mode does not work and a shop could not find the cause. The owner asks whether towing a 4500 lb trailer 500 miles without tow mode could damage the engine or transmission. The expert explains that tow mode only locks out overdrive, suggests using the next lower gear, and suspects a transmission electrical problem while asking about a check engine light.
