2004 Chevy Silverado Rear Seal Leak
GERSH1SAM
I am asking this question for my husband, so please bear with me. I believe he is asking about the axle seals (the first thing on the spindle?). I have a 2004 chevy silverado dually 3500 diesel. Approx 68,000 miles. Auto with a push button 4WD. He just replaced my brakes, and something is leaking in between the dually wheels on both sides. It smells and smokes when the truck is driven. Front brakes are a bit squeeky, but dont think it is related. I have brake pressure. My husband wants to know how to replace these seals/plugs. THANK YOU :shock:
Sep 10, 2007 at 11:09 AM
DENNYP
  • 1,824 POSTS
[quote:fa535314d3="gersh1sam"]I am asking this question for my husband, so please bear with me. I believe he is asking about the axle seals (the first thing on the spindle?). I have a 2004 chevy silverado dually 3500 diesel. Approx 68,000 miles. Auto with a push button 4WD. He just replaced my brakes, and something is leaking in between the dually wheels on both sides. It smells and smokes when the truck is driven. Front brakes are a bit squeeky, but dont think it is related. I have brake pressure. My husband wants to know how to replace these seals/plugs. THANK YOU :shock:[/quote:fa535314d3]if it has rear disc brakes,then you must remove the rear calipers and brackets,then remove the hub assemblies.the seals will be in the back side of the hubs
Sep 29, 2007 at 9:07 AM
Suggested Repair
If the truck has rear disc brakes, remove the rear calipers and brackets, then remove the hub assemblies. The axle seals are on the back side of the hubs.
Conversation Summary
The owner of a 2004 Chevrolet Silverado 3500 dually reports fluid leaking between the dual rear wheels on both sides after a brake job, with odor and smoke while driving. The expert says that if it has rear disc brakes, the calipers and brackets must be removed, then the hub assemblies; the seals are on the back side of the hubs.
