Pickup sputters
BURGAN
82 Chevy pickup sputters and sometimes dies. Not much power. ANy ideas?
Nov 21, 2007 at 9:40 PM
PEAR69
  • 1,482 POSTS
Yep, the fuel pumps go out all the time in these trucks. Here is how to test it and change it out, also change out the fuel filter first which can help. Here is the location of the fuel filter so you have a place to start.
Removal
1. Disconnect fuel inlet line from pump.
Disconnect vapor return hose, if so equipped.
2. Remove two bolts holding fuel pump.
3. Remove fuel pump, push rod, gasket and mounting plate (if used).
Installation
1. Install push rod, gasket, mounting plate (if used) and fuel pump.
2. Install two hex head bolts, turning them alternately and evenly.
3. Install fuel outlet pipe. If it is difficult to start fitting, time can be saved by disconnecting upper end of pipe from carburetor. Tighten fitting securely, meanwhile holding fuel pump nut with a wrench. Install and tighten fitting at carburetor, if removed.
4. Install fuel inlet hose and clamp. Install vapor return hose and clamp, if so equipped.
5. Start engine and check for leaks.
Please go over this guide as well.
https://www.2carpros.com/articles/engine-has-low-power-output
Please go over this guide and get back to us.
Nov 22, 2007 at 1:37 PM
