1992 Chevrolet Silverado Acceleration Jerk
BULLDOG6822
1992 chevy 1500 4.3 155,000 miles starting to have problems at times with acceleration speed while on the gas it will start jerking and sputtering but if i back off the gas it will stop. the truck has a good idle but just while accelerating is the problem and this is not a constant problem just on occasion. ive tried seafoam and water remover to see if i got some bad gas but it didnt help
Feb 16, 2007 at 10:11 AM
GARFIELD
  • 197 POSTS
I would check out your throttle position sensor, they normally wear out at just off idle and around the bottom third of the sensor since it spend most of the time in that area of the switch.
Feb 16, 2007 at 11:02 AM
CHEVY22
  • 1,375 POSTS
also i like to check simple things first , how long ago was the last set of plus put in and what brand??
jim
Feb 16, 2007 at 6:26 PM
SILVERADOGIRL13
Had them same problem...tried the water remover and such. Changed the oxygen sensor worked great
Feb 17, 2007 at 2:30 AM
Suggested Repair
Check the throttle position sensor, which often wears just off idle, and confirm when the spark plugs were last replaced and what brand was used. A similar case was reported fixed by replacing the oxygen sensor.
Conversation Summary
A 1992 Chevrolet 1500 with a 4.3 engine intermittently jerks and sputters under acceleration but idles normally. Fuel additives did not help. Experts suggested checking the throttle position sensor and the age and brand of the spark plugs. Another owner reported the same symptom was resolved by replacing the oxygen sensor.
