1998 Chevy Silverado Pump Runs Constantly
DCMMEME
I installed a new fuel pump on my 1998 Silverado, 2WD, 120,000 miles. The pump seems to run constantly. I don't remember hearing the noise before of it running. Is there a problem?
May 19, 2007 at 4:09 AM
  • 75,988 POSTS
[quote:0bc704fd1b="dcmmeme"]I installed a new fuel pump on my 1998 Silverado, 2WD, 120,000 miles. The pump seems to run constantly. I don't remember hearing the noise before of it running. Is there a problem?[/quote:0bc704fd1b]
The pump seems to run constantly is this KOEO its not suppose to do that. When in KOEO the pump should come on for a few secs and then cuts off.
May 19, 2007 at 10:37 AM
Suggested Repair
With the key on and the engine off, the fuel pump should run only a few seconds to prime, then shut off. Continuous running in that condition is not normal and should be checked.
Conversation Summary
The owner of a 1998 Chevrolet Silverado installed a new fuel pump and noticed it seems to run constantly, unlike before. The expert said that with the key on and engine off the pump should come on briefly and then cut off, so constant running in that state is not normal.
