1994 Chevy K1500 Dash Lights Out
SIRLANCE
1994 chev k 1500 4x4 5.7 engine
Awhile back I was having problems with tail light and instrument panel light fuses blowing. I replaced the light switch and instrument panel and dome light switch.
when I turn on the lights not important if just parking or all of them and adjust my dimmer switch for the instrument panel the lights in the dash do not come on and it will kill the heater lights in the dash. It also makes the dimmer switch get hot and the heater blower and plights seem to dim out when trying to turn on the light in the dash. Due I have a faulty circuit panel behind my dash?
Feb 5, 2007 at 10:26 AM
JDL
  • 16,098 POSTS
Sorry for the late reply. If it is blowing fuses, check the wiring diagram for everything on that fuse circuit. Check the circuits one at a time, check voltage and ground.
If the dimmer switch is getting hot to the touch, maybe faulty dimmer switch or the wiring in the steering column. Even with multiple issues, by fixing one circuit may fix some of the others.
Mar 14, 2015 at 6:10 AM
Suggested Repair
Check the wiring diagram for everything on the blowing fuse circuit and test each circuit for voltage and ground. Because the dimmer switch gets hot, inspect or replace the dimmer switch and check the steering column wiring; correcting one circuit may resolve related light problems.
Conversation Summary
The owner of a 1994 Chevrolet K1500 with a 5.7 engine reported tail light and instrument panel fuses blowing. After replacing the light switch and the instrument panel and dome light switch, the dash lights still do not come on when the dimmer is adjusted, the heater lights go out, the dimmer switch gets hot, and the blower and lights dim. The expert advised checking the fuse circuit wiring one circuit at a time for voltage and ground, and suspected a faulty dimmer switch or steering column wiring.
