When I first start it in the morning it idles normal, about 500 but after driving a few it idles anywhere from 1000 to 1500. I can turn off the engine and it once again will idle fine until I drive it a few miles. Any suggestions?
2000 Chevy Silverado High Idle After Drive
When I first start it in the morning it idles normal, about 500 but after driving a few it idles anywhere from 1000 to 1500. I can turn off the engine and it once again will idle fine until I drive it a few miles. Any suggestions?[/quote:2bf255f0c8]
Try checking the throttle position sensor and clean out the idle air control valve, also the throttle body/plate and a binding throttle cable.
I almost forgot about the coolant temperature sensor-test its resistances hot and cold-could be stuck in the open loop mode and the computer is dumping fuel thinking the engine is still cold.
Suggested Repair
Check the throttle position sensor, clean the idle air control valve and throttle body/plate, and inspect for a binding throttle cable. Also test the coolant temperature sensor resistance hot and cold, since a faulty sensor can keep the engine in open loop and add fuel as if it were still cold.
Conversation Summary
A 2000 Chevrolet Silverado 5.3 4x4 idles normally at about 500 rpm on a cold start, then idles at 1000-1500 rpm after a few miles of driving. Restarting restores normal idle until it is driven again. The expert recommends checking the throttle position sensor, cleaning the idle air control valve and throttle body/plate, checking for a binding throttle cable, and testing the coolant temperature sensor hot and cold for a possible open-loop fueling issue.
