I have a 1992 chevy stepside 1500 automatic 350 with 160k mi
JROBB
Brake lights do not work - blinkers do and rear tail lights - anyone know whatup - fuse is ok too!
thanks
Feb 18, 2007 at 2:37 AM
SERVICE WRITER
  • 9,123 POSTS
Brake lights are a seaparate filiment, did you try changing the bulbs?
Feb 18, 2007 at 3:10 AM
JROBB
did the eye to the sky - looked good but replaced them anyhow to be sure.
Feb 22, 2007 at 7:27 AM
SERVICE WRITER
  • 9,123 POSTS
If you can check to see if power is getting to the sockets, that would be best, it may be socket problem. If no power to them may be brake light switch on the brake pedal roughly.
Feb 22, 2007 at 9:19 AM
JROBB
Thanks I'll get out the test light and check the sockets - do you know how much the brake light switch generally runs?
I appreciate your time & consideration - I'll kick in some loot ere directly thru paypal - thanks.
Mar 9, 2007 at 3:02 AM
