help needed
STEVETHETOOLMAN
98 Chevy siverado, 5.7L R 120,000mi
took the bolts out of the upper intake, to change fuel injectors, the upper intake will not come off, you can turn it side to side and up and down some but will not come out. any suggestions? thanks
Nov 10, 2007 at 1:46 PM
BMRFIXIT
  • 19,053 POSTS
[quote:0316ebb11f="stevethetoolman"]98 Chevy siverado, 5.7L R 120,000mi
took the bolts out of the upper intake, to change fuel injectors, the upper intake will not come off, you can turn it side to side and up and down some but will not come out. any suggestions? thanks[/quote:0316ebb11f]
is it stuck on the valve covers
u need to remove them u know
good luck
Nov 10, 2007 at 2:01 PM
STEVETHETOOLMAN
it is not by the valve covers
Nov 10, 2007 at 2:08 PM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_98chevy_1.jpg
Nov 10, 2007 at 2:22 PM
