Fuel pump press
KATYKARTER
Sorry I can't donate at this time
2000 Chevy Silverado
118K milage, 4.8l
I replaced fuel pump, changing the plug terminal to new one, wiring it into harness.
Is there a fuel pressure issue, do I need to bleed air from the lines, or did I miss a step at disassembly?
Truck won't start, not getting fuel.
Sep 9, 2007 at 2:05 PM
SERVICE WRITER
  • 9,123 POSTS
Bad pump off the shelf? Fuel filter plugged?
Sep 9, 2007 at 2:18 PM
KATYKARTER
thanks for the reply
no, this is second pump. 1st pump failed 6wks ago, it failed (according to parts guy) because my mechanic/friend didn't switch the harness plug end, which I did yesterday.
Filter replaced less than one week ago at sched. maint interval
will recheck wiring splices and filter
Sep 9, 2007 at 11:54 PM
SERVICE WRITER
  • 9,123 POSTS
So the fuel pump pressure is in spec?
Sep 10, 2007 at 12:29 AM
