Fuel pressure
FRANCEJEFF
I have a 1997 chevrolet 3/4 ton pu and replaced the fuel pump several times it has 205000 miles and now when I first try to crank it it acts as if the fuel pump is not working. If I leave the key on for 1 1/2 to 2 minutes it will try to start and after a few attemps of this procedure it will crank and run fine. Is there some sort of pressure switch or regulator that could be bad?
Nov 19, 2007 at 5:10 AM
  • 75,988 POSTS
Check the fuel pressure again, test the fuel pump relay and fuel pump/oil pressure sending unit. See below
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_17.gif
www.eautorepair.net
Nov 19, 2007 at 5:48 AM
