2003 Chevrolet Silverado Idle Issues
Suggested Repair
Clean the throttle body, then relearn minimum idle speed: disconnect the negative battery cables for a couple of minutes and reconnect them. Set the parking brake, block the drive wheels, start the engine, shift to Drive with your foot off the brake, and idle for 5 minutes. Shift to Park and idle for 5 minutes, shut the ignition off for 1 minute, then restart and road-test.
Conversation Summary
A 2003 Chevrolet Silverado 2500HD 6.0 would only click and not start because the battery was low. After a jump-start and battery replacement, it started but idled very low and nearly stalled in Drive, and the A/C alternated between cold and hot air. An expert recommended cleaning the throttle body and performing a minimum idle-speed relearn. A later commenter said the same procedure did not fix a similar Silverado and asked about buying the truck; the original owner did not confirm the repair.
