1994 Chevrolet Silverado Hard Shifting
FLYINBRYAN2005
i have a Chevrolet Silverado 1994 model, 67,000 miles, and 350v8. My truck runs fine whenever the engine light is off, but every once in a while it will come on. When this happens, the transmission shifts hard out of park, reverse, drive, etc. i lose overdrive, and it shifts out of first gear pretty rough. all i have to do is turn the key off and restart it and it runs fine. i may have to restart about 3 times. also, this may be a different problem, but the truck idles funny when this happens.it is not the transmission b/c if this was the problem, it would be shifting hard every time. this is not the case. [img:b260f64e8d]http://www.2carpros.com/forum/automotive_pictures/58605_Picture_001_1.jpg[/img:b260f64e8d]
[img:b260f64e8d]http://www.2carpros.com/forum/automotive_pictures/58605_Picture_002_1.jpg[/img:b260f64e8d]
Feb 10, 2007 at 4:55 AM
JDL
  • 16,098 POSTS
Sorry for the late reply. My first thought was to check vehicle speed sensor. Check applicable trouble codes. If you fully obd1 compliant, you can check some codes, yourself.
Mar 14, 2015 at 5:28 AM
Suggested Repair
Check the vehicle speed sensor and retrieve applicable trouble codes. If the truck is fully OBD1 compliant, some codes can be checked without a scan tool.
Conversation Summary
A 1994 Chevrolet Silverado with a 350 V8 runs normally until the check engine light comes on intermittently. When the light is on, the transmission shifts hard, overdrive is lost, and idle is rough; cycling the key several times restores normal operation. The owner does not believe the transmission itself is failing because the problem is not constant. The expert recommends checking the vehicle speed sensor and reading applicable trouble codes, noting that some OBD1 codes can be checked by the owner.
