1991 Chevy Silverado Rough Idle
DADDYOFZAKK
my 1991 chevy 1500 runs real bad at an idle but only some time.ive done the whole tune up thing.and it did not help.and when i floor it,it will spit like it is not getting enough fuel but only sometimes..im pretty good at this i mean its only a 350 v8...thank you in advance for your time
Oct 24, 2007 at 2:20 PM
  • 75,988 POSTS
Lets find the idle air control valve/EGR and also check the closed and wide open throttle voltages of the throttle position sensor/ to include the MAP sensor.
Might also want to check the exhaust system for restriction.
Oct 24, 2007 at 7:32 PM
Suggested Repair
Check the idle air control valve and EGR system, measure throttle position sensor voltage at closed and wide-open throttle, test the MAP sensor, and inspect the exhaust for restriction.
Conversation Summary
The owner of a 1991 Chevy 1500 with a 350 V8 reports an intermittent rough idle and occasional spitting under full throttle after a tune-up. The expert recommends checking the idle air control valve, EGR, throttle position sensor voltages, MAP sensor, and exhaust restriction.
