Airconditioning has 50 psi on low side with compressor running and accumulator low pressure switch jumpered out. When switch is connected to accumulator compressor will not run. 12 volts to switch and nothing out. Can the low pressure switch be bad,changed out without pumping down system as noted in this forum? What pressure does the switch open and close at?
1994 Chevrolet Silverado A/C Switch
Gary
Does anyone know what the cut out and cut in pressures are for the low pressure switch on the accumulator of a 94 silverado are? What Pressure should one run the freon on low and high side of this vehicle with 134a?
Suggested Repair
The low-pressure switch may be failed if it has 12 volts in and no output while the compressor runs when the switch is jumpered. Check a replacement accumulator to confirm a Schrader valve behind the switch; if present, the switch can be unscrewed without evacuating the system, otherwise evacuate first. Use roughly 35-45 psi low side and about 185 psi high side, not over 200 at idle, with about 70 psi static when off. If converting from R-12, charge only about 70-75% of the R-12 amount and use a condenser fan while charging.
Conversation Summary
A 1994 Chevrolet Silverado with R-134a has about 50 psi on the low side and the compressor runs only when the accumulator low-pressure switch is jumpered. With the switch connected, 12 volts is present but nothing comes out, so the compressor will not run. The owner asked whether the switch can be replaced without pumping down the system and what its cut-in and cut-out pressures are. The expert said a Schrader valve may be behind the switch and recommended checking a new accumulator at a parts store; if no valve is present, evacuate the system first. Exact switch pressures were not given, but suggested operating targets were about 70 psi static, 35-45 psi suction, and around 185 psi discharge, not above 200 at idle, using roughly 70-75% of an R-12 charge if converting.
