RANBA
I have a 99 silverado 4.8 multiport fuel inj It won't start unless i turn the key forward to on and then back to off about 2 or 3 times, and then it fires right up. Any ideas?
Jan 14, 2006 at 1:27 PM
DODGE89
  • 33 POSTS
when you turn it on to start theres no crank and does everything go out dash lights dome etc.
Sep 2, 2020 at 7:47 AM
RANBA
It will crank over if i try to start it , but it won't start until i have turned the key to the on position and back to the off position 2 or 3 times.All lights and everything comes on
DODGE89
  • 33 POSTS
can you tell if there is spark.
RANBA
I have'nt checked.
DODGE89
  • 33 POSTS
check to see if it has spark. if it has spark. then it could be a fuel prblum if it dosnt have spark then it would be electrical (stater,coil, spark plug wire.)
Sep 2, 2020 at 7:48 AM
RANBA
ok, thanks
