I have a 1988 K1500, 350 with automatic trans, the truck has around 265,000 miles on it.
It quit on me the other day while driving it.
sounded like a fuel pump (as i have replaced the fuel pump a couple of times)
The truck did this a few years ago as well and i ended up changing the ignition coil to fix that.
this time i have changed the fuel pump, fuel filter, ignition coil, fuel pump relay, and checked fuel pump fuse.
What could i be missing?
the truck turns over just sounds like it isn't getting any gas.
I did pull the injectors the other day and thy had fuel in them. could it be the inj filters?
or the pressure regulator?
if you put a little gas in the carb it sound as if it is catching, but not enough there to keep it going.
Jul 18, 2007 at 6:06 AM
