2009 Chevy Silverado mirrors
400 MILES • V8 • 4WD • AUTOMATIC
MIKE SILVERADO
I have an 09 silverado 2500 HD. I have stock power heated mirrors without turn signals in them. I want to purchase OEM style aftermarket towing mirrors . If I purchase power heated mirrors with the turn signals will they plug into electrical connection and work? The turn signal question is whats up in the air as my local Chevy dealers can't answer it for me! I was told to check the connection ends to make sure they are compatible but since I am purchasing over the internet I can' do this! Has anybody done this and wiill they work? thanks for the help!
Mar 25, 2010 at 1:05 PM
DENNYP
  • 1,824 POSTS
I can't say if they will work or not. I can tell you that installing aftermarket parts that connect to the electrical system can cause you problems later. If that part fails and causes any damage to a control module or wiring, there will be no warranty through GM. I'm not saying this will happen. I am just giving you a heads up.
Mar 26, 2010 at 1:55 PM
