2008 Chevy Silverado tire monitor sensor
2008 CHEVROLET SILVERADO
15,000 MILES • V8 • 2WD • AUTOMATIC
CRUZ74
Can the tire pressure sensor be removed from the original steel rim and take the original tire and mounted them on a set of 2006 silverado LT Rim?
Feb 14, 2009 at 12:07 PM
BRIAN 1
  • 1,030 POSTS
yes,the valve stems are all the same.seeing as you are going from OEM rim to OEM rim it should work.post back with any other questions.
Feb 15, 2009 at 3:52 AM
