2008 Chevy Silverado Option code for tires from Medium duty
18,000 MILES • 6 CYL • 2WD • AUTOMATIC
VARTZ04
I need to change the rear end gear ratio in my truck, I have put bigger tires on it and the 3.23 stock gears aren't cutting it.
I am putting 4.10 gears in it. I was told by a dealership that they could not adjust the gear ratio in the new trucks pcm but tire size could be changed.
My idea is this, put a big enough tire in the computer to make the truck seem like its still running the 3.23 gears. That means a 38" tire, they just so happen to ahve this option in the C5500's its option code XTU.
that is a 265/75/22.5 tire, Can this be downloaded using the tech II scanner to a silverado PCM
Oct 12, 2009 at 2:38 PM
BRIAN 1
  • 1,030 POSTS
it could,the tech 2 will change the tire size in the special functions part of the tech 2,it will just recalibrate the EBCM to read a faster or slower wheel speed.but a tire that big might not be an option in the tech 2.there are only so many sizes to calibrate in the tech 2. I guess you could try it.sometimes you need a VCI number from GM to calibrate it,if that option is avalible.
Oct 13, 2009 at 11:16 AM
