2008 Chevy Silverado Dome light does not come on when unloc
2008 CHEVROLET SILVERADO
4,050 MILES • V8 • 4WD • AUTOMATIC
MUDMULE
Right after purchasing my new truck (2008 Chevy Silverado) an attempt was made to install an after market remote start. After many attempts to make it work correctly it was uninstalled. Since this event I've noticed when using my remote keyless entry or opening the door my dome light no longer comes on. All my dash lights work. I've checked the switch and still no dome light. I can manually turn the dome light on. How do I fix this?
Nov 7, 2008 at 1:11 PM
RACEFAN966
  • 5,029 POSTS
If you door jam switch is still good then you will need to go back through the wiring as you did the install of the remote start and find which wire is no longer connected or broke and fix it.
Nov 8, 2008 at 12:52 AM
