2007 Chevy Silverado The air conditioner wont work.
NAVYGUY76
  • 2007 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 67,000 MILES
The air conditioner wont work. One day I pulled in and turned the engine off and the air kept going. I pulled the fuse and it turned off. Now I plugged the fuse back in and it worked for a few day and now it quit. I cant even get the heater to work. What can I do to fix the problem?
Monday, July 26th, 2010 AT 3:58 PM
  • 110,053 POSTS
What fuse was removed? Is it the blower motor fuse?
Monday, July 26th, 2010 AT 9:30 PM
NAVYGUY76
Yes I removed the blower fuse. It was a 10 green fuse. Do you think my blower may have gone bad or do you think the wiring is bad? I am gonna try to replace the fuse today but I have doubts that is what it is.
Tuesday, July 27th, 2010 AT 5:05 AM
  • 110,053 POSTS
It could be a few things. What I need you to do is check the blower motor (when not working) to see if there is power to it. If there is power, the motor is the problem. If no power is present, then I walk you backwards through the system. It's not as bad as you would think. The blower motor is under the dash on the passanger side of the vehicle.
Let me know what you find.
Tuesday, July 27th, 2010 AT 9:00 PM
Related Air Conditioner Not Working Content
Fix an Air Conditioning Not Working Video
VIDEO
