2007 Chevy Silverado oil leak
24,000 MILES • V8 • 4WD • AUTOMATIC
AWOOD81
My truck is leaking oil, it is a slow leak that collects around the drain plug. When you look at it, it looks like it leaking from around the oil pain gasket. I took it to the dealership and they changed the oil pain gasket, 700 miles later it started leaking again. I took it back to the dealership and they changed the rear seal. It has been about 300 miles and it starting to leak again. The block and the front of the oil pan is clean. What do you think?
Jun 25, 2008 at 1:02 PM
MASTERTECHTIM
  • 4,750 POSTS
did they change the rear engine housing gasket and clean all the oil plugs and put teflon on them. my guess is thats where the leak is. thats the only thing i see leak on this engine
Jun 25, 2008 at 1:08 PM
AWOOD81
The dealership said they changed the rear seal
Jul 2, 2008 at 1:17 PM
AWOOD81
I dont now if they put teflon on any thing
Jul 2, 2008 at 1:18 PM
MASTERTECHTIM
  • 4,750 POSTS
there is a cover that the rear main seal goes into that attaches to the rear of the engine and there is a gasket there that leaks.
Jul 3, 2008 at 7:20 AM
