My truck is leaking oil, it is a slow leak that collects around the drain plug. When you look at it, it looks like it leaking from around the oil pain gasket. I took it to the dealership and they changed the oil pain gasket, 700 miles later it started leaking again. I took it back to the dealership and they changed the rear seal. It has been about 300 miles and it starting to leak again. The block and the front of the oil pan is clean. What do you think?
Jun 25, 2008 at 8:02 PM
