2006 Chevy Silverado Virtually no airflow through vents
2006 CHEVROLET SILVERADO
38,000 MILES • V8 • 4WD • AUTOMATIC
IMBACK348
When I turn on either the heater or air conditioner in my truck I get almost no airflow out of the vents. The flow is slightly less than the flow used to be on the systems lowest setting but I can feel some flow. The cabin air fliter is not clogged and I wasn't sure if this meant it was the blower motor or if it could possibly be a defective switch or sensor. Also before tearing into the truck how do I know if my blower motor is tab or bolt mounted as I have seen both listed for the truck
Oct 1, 2009 at 5:48 AM
  • 110,244 POSTS
You need to first access the motor to see if it is getting power. Chances are you have a bad relay or resister if there is no power to the motor. IF there is power, replace the motor.
Oct 8, 2009 at 1:23 AM
