2006 Chevy Silverado tighten fuel cap warning
28,000 MILES • V8 • 4WD • AUTOMATIC
BOLTONR
I got a tighten fuel cap warning and then the check engine light came on. Tightening the fuel cap did not fix the problem, so I bought an OEM replacement which immediately fixed the problem for about one month and 500 miles of driving. Now I have the same problem.
May 7, 2010 at 12:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
There are all sorts of things that can cause that issue. The evaporative emissions system runs a test to ensure no fuel vapors are escaping into the atmosphere. The vehicle simply assumes the gas cap is loose based on the rate of leakage. It could be a leak at the filler neck, tank itself and/or any of the evap valves. This doesnt mean it leaks fuel, but rather fuel vapors from the emissions system.
May 7, 2010 at 4:30 AM
