How do you replace the bulbs in the ac temperature panel?
Jun 9, 2010 at 12:20 PM
BLUELIGHTNIN6
✓Experienced Mechanic
have to remove the HVAC control assembly. remove the trim plate bezel around it, then remove the storage tray and accessory switch assembly from instrument panel. remove the screws from the HVAC controls and slide it out to access bulbs.
