2006 Chevy Silverado instrument bulb replacement
48,000 MILES • V8 • 2WD • AUTOMATIC
NWBENSON
How do you replace the bulbs in the ac temperature panel?
Jun 9, 2010 at 12:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
have to remove the HVAC control assembly. remove the trim plate bezel around it, then remove the storage tray and accessory switch assembly from instrument panel. remove the screws from the HVAC controls and slide it out to access bulbs.
Jun 9, 2010 at 3:15 PM
