2006 Chevy Silverado Hitch socket wiring
2006 CHEVROLET SILVERADO
SHADOWEN1
  • 15 POSTS
Electrical problem
2006 Chevy Silverado V8 Four Wheel Drive Automatic
I need to re wire the 7 pin trailer wiring plug on my silverado. I have 8 wires for the harness and have figured out the turn signals, reverse and tail lights but what are the other 4 wires? The colors I have are: 3- 10ga; red, black,dark blue and 5- 16ga; brown, light bue, dark green, light green, yellow.
Feb 28, 2009 at 9:17 AM
BRIAN 1
  • 1,030 POSTS
sorry for the delayed response,here is the info:Pin
Wire Color
Circuit No.
Function
A
L-GN
1624
Trailer Backup Lamps Supply Voltage
B
BK
1550
Ground (30 Series Except Chassis Cab)
BK
1650
Ground (30 Series Chassis Cab)
BK
1750
Ground (10/20 Series)
WH
22
Ground (UY2)
C
D-BU
47
Trailer Auxiliary Supply Voltage
D
D-GN
1619
Trailer Right Rear Turn/Stop Lamp Supply Voltage
E
RD
742
Battery Positive Voltage
F
BN
2109
Trailer Park Lamps Supply Voltage
G
YE
1618
Trailer Left Rear Turn/Stop Lamp Supply Voltage
post back with any other questions and will help with more info.
Mar 1, 2009 at 1:30 AM
SHADOWEN1
  • 15 POSTS
I really apreciate the info. Just to make sure I've got it right. The dark blue 10ga will go to the electric brake hook-up on the socket and the red 10ga. will go to the fused battery lead on the socket. I guess the only other question I would have is, in the wiring there is a light blue 16ga. wire that only has power with the brakes applied. I had assumed this would splice into a lead for the brake lights but, there is'nt one on the socket. What do I do with that wire? Thanks again.
Mar 1, 2009 at 4:40 AM
BRIAN 1
  • 1,030 POSTS
is this an aftermarket connector or an OEM connector.sorry but its been a while since I did one of these.I'LL help as best I can.its hard to picture the connector.post back with what you find.
Mar 1, 2009 at 5:15 AM
SHADOWEN1
  • 15 POSTS
I am trying to wire in a n aftermarket Hopkinns kit #40955. Would it help if I uploaded a pic of the wires I am looking at?
Mar 1, 2009 at 6:23 AM
BRIAN 1
  • 1,030 POSTS
yes it would help if you had a picture.you might also want to see if the web site that manufactors this part has a scematic or diagram,it might help.
Mar 1, 2009 at 9:48 AM
SHADOWEN1
  • 15 POSTS
Here are some pics of what I am looking at. I am planning to slice the wires to the wires off this plug. I hope this is helpful.
https://images.2carpros.com/forum/automotive_pictures/288001_P1030727_1.jpg
https://images.2carpros.com/forum/automotive_pictures/288001_P1030728_1.jpg
https://images.2carpros.com/forum/automotive_pictures/288001_Picture_001_1.jpg
Mar 1, 2009 at 12:11 PM
BRIAN 1
  • 1,030 POSTS
pretty good pictures,couldnt read the diagram at the bottom,was to small.here is the connector,maybe it will help.
https://images.2carpros.com/forum/automotive_pictures/147643_trailer_1.jpg
I havent had much time to really look into helping you,sorry but I've been busy.post back if this helps and I will assist.
Mar 2, 2009 at 10:04 AM
