2006 Chevy Silverado Fan
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
BACKYARD2
The AC fan will not come on. The compressor clicks on. The light on the dash lights up indicating that the compressor is on. This happenned once before, but lasted only one or two times that I re-started the ignition. The fan has 5 speeds, but the 5th speed has not worked in quite a while. If the fan motor has frozen, where is it located?
Sep 13, 2010 at 10:43 AM
WRENCHTECH
  • 20,760 POSTS
The motor is located under the dash on the passenger side. Test for power and ground arriving at the motor..
Sep 13, 2010 at 12:16 PM
