I have '06 Silverado, I just recently got the slave cylinder replaced, and a new clutch assembly put in and resurfaced the flywheel. The problem I'm having now is that when I try to start off in first gear the truck shudders like it's going to stal, I know that it's probably me needing to get use to the new clutch. The big problem though is when I go in reverse, it does it even worse no matter how much gas I give. Note that it stop as soon as the clutch is all the way out. I was wondering if this is normal or if the shop that put the new clutch in used a lighter duty one or if they didn't replace something properly.
Nov 7, 2009 at 11:01 AM
